smokin150
aka Diesel Weasel
After replacing the wonderfully worn out autocrack glow plugs wit new zd9s( and finding out they are actually smaller diameter points then zd9 plugs which allowed carbon to build around them... much fun *eye rolls* ) I now have a few new issues, first being an increase in blue smoke and a random knock. The smoke I can kinda deal with as it clears up a little after I pass 150* eng temp. The knock however has me worried. Its not loud all the time nor is it consistent, it die however seem to be comming off the pass side of the engine. Now while I was in there I did fuel pressure test at the filter head and at idle got 3.5-4 psi with heavy needle bounce (still on mech pump) with no change at hi idle no load. Im going to try and get cold start and warm idle video of the truck to assist with diag. Any input would be helpful as I need to make this thing last till I have the time/money to get my Volvo up and running.
Truck info
88 7.3idi NA
3" exhaust
Soup bowl mod
Fuel turned up 1/2 flat
Bb code injectors
Truck info
88 7.3idi NA
3" exhaust
Soup bowl mod
Bb code injectors
