tadd
So the last of the big project that are almost currently completed was replacing the fuel tank. If you look close at the square tank in the last pic of the first post, it was crunched when I bought it. Winters salt most likely wasn't kind and it started a slow drip most likely due to crevice rust.
Found an MRAP tank in VA for a good price and its a bit bigger than what I had. So just needed to mount it. Time to break out the metal saw and TIG.
Here is the brackets and tank to give an idea while I was thinking things up:
Since the mog frame is designed to twist, I wanted to make sure the tank mounts would give, so I went with a 'big rig' style strap mount.
Mike made the pins for me from stock. Off the shelf pins were stupid expensive.
Completed strap holder with strap on tank...
Just needed the bits to weld on that bolts to the truck now...
Photo limit so on to next post!
