HSkinner
I recently replaced the master cylinder with an autozone unit only because I was in a bad way and they had it. They asked me if the truck was over or under 8500gvw and I said it was over and I now realize that an 86 ext cab f250 is not over 8500gvw. I bench bled it and then still bled it at all of the wheels. I've been driving it on and off for about a month and there is definitely something off. When I press the pedal it is a delayed reaction and the pedal is very hard to push. I checked for obvious vacuum leaks and couldn't see anything. Is there anything I can do to fix this? Can I connect the vacuum pump directly to the booster to determine if there is a leak somewhere in between? I've read a little about the hydroboost conversions but I would prefer to figure this out first before going that route. Is the master cylinder the cause of this? There is a coffee can looking canister mounted on the inner fender well on the driver side. is this factory?
