ya i been getting a lot done lately, thanks.
next is inspection some more wiring and remounting the pass seat belt.
then im going to finish the turbo and hook up the airhorn.
i think with some good turbo whistle the exhaust will sound awesome
plus that turbo will get me around 300 - 350 hp im guessing and torque no idea well see
theres a dyno shop across the street from work that i plan to hit for a before and after for the turbo then i got one of russ's cams that i will install and dyno after again but the cam will be over winter sometime. also im planning a bolt up rear disc setup with built in ebrake but if i cannot find a good caliper i have to do a 5 speed swap before so i have the driveline brake. and of corse a divorced 205 will be needed.
then finally a 60/ drw swap and 19.5s and i think ill be done
but if anyone wants a write up for a how to let me know ill make one cause the one in the tech threads confused me
