f-two-fiddy
My 85 NA is not gutless. Very comparable to a 460. Timing, timing, timing!
no pyro
It seems to be getting more gutless! I don't know if the exhaust I had put on it is too big? Is that possible? Maybe the new fuel filter I put on it is getting plugged?
Anyway I have been reading threads on every diesel forum I can find. Like you guys everybody is saying to advance the timing.
So I marked the IP and the housing so I would have a referance. BTW the IP has a sticker from a rebuilder so it's rebuilt.
I loosened the 2 easy to get to nuts. Then I had to cut down a cheap wrench to get the 3rd nut loose. As soon as I loosened that last nut the IP spun to the dr side.
I had to really fight it to even get it back where it was. I ended up with it advanced(towards passenger side) about .030 from where it was. Went on a test drive...Runs the same.
Doesn't sound any different.........should I go more?
How do I adjust the idle? It's idling pretty fast now.
.......They all told me that they just lined up the marks when replacing a pump so they were no help. Most of the places I called were diesel repair shops!
