Hydro-idi
Hey everyone I need a little input here. For a while, I've been noticing my truck shifts different when my truck sits overnight and engine is cold. Since winter is approaching and temps are decreasing, it seems to be more evident and shifts even harder when cold but smooths out once truck is warmed up. It also has delayed shifts.....rpm's go up more than normal and wait for it to shift. Around 2,200-2,500 rpm it will clunk into gear. Often times I will just let of throttle and it drops right into gear when cold. It does this for a few miles. My question is, is this just the nature of these transmissions or does something need to be adjusted? Again, when engine hits operating temp, transmission shifts just fine.
The transmission has been rebuilt approximately 70k ago, fresh atf about a month ago, and band adjusted properly.
Any help would be greatly appreciated guys thanks !
