Murphys trip from hell
timothyr1014
chandler. az
All I can say is wow….If I didn’t love my IDI so much it would be over…….
850 total miles in 48 hours…and here is the quick lowdown on what all went on. The amazing thing is it came home on its own power, I am stunned I did not have to have it pulled home; and I will say it makes me appreciate my “emergency kits”…
1. The PO’s version of stereo wiring gave up the ghost...emergency kit: compact LED flashlight (runs forever on 3AAA batteries and is VERY bright) $7 harbor freight multimeter, wire cutter, 3’ of wire with 20 amp fuse, butane soldering iron, and electrical tape…result, bad wiring cut, dash lights wired to ignition, no music, but I can still watch my gauges
2. Put the hammer down pulling out of a truck stop…smell of coolant….heater core (fortunately leaked outside the truck)…emergency kit: 5/8” coupler – result: bypassed
3. Round of crap fuel started stalling on the freeway 50 miles from civilization…emergency kit: strap wrench, fuel filter, 1 gallon of ATF…Result: got it to a truck stop 75 miles later, added a crap load more of ATF to what was left in the tanks and made lemonade from lemons…true smoke style.
4. Ignition cyl took a crap in the “Run position”…emergency kit: same tools from item 1, and a 20 amp toggle switch…result: switch on the red/green wire to shut it down.
5. Slammed on the brakes, the motor sitting in the bed had an accessory that had just enough reach to destroy my back window (second one this month…time for a headache rack). Emergency kit: duct tape…result: cant see out the back window, but without a heater on a 35* night no vision is better then cold wind
6. And finally, ½ mile from the freeway exit for home (and 7 blocks of surface street) had an injector return line (looks like) give it up totally (as I am passing a highway patrol officer no less)…smoke screened an entire 4 lanes of freeway…diesel running out from the valley pan and down the front of the motor. Emergency kit: duct tape and fuel line….result: a slow drip, crappy fuel pressure, almost no power, and limped it home letting it cool down for 20 mins 3 times over a 6 mile stretch…yes driving with a rigged and leaking fuel system is not smart, but I wanted to get home, and I have a decent fire extinguisher on board and there weren’t many other cars on the road…so we rolled the dice
$200 into emergency supplies that always stay in the truck, and wireless internet (thanks to all who responded to my pleas for info), and we rolled home safely for thanksgiving. In as much as it was stressful and frustrating it was nice to have something so freaking simple to work on
dave186
Idaho
I guess i am lucky, drove my IDI from Boise to Seattle and back without a single issue. On 25% WMO too thanks to my 100 gal transfer tank. Just over 1200 miles by the time I was done without one stop at a gas station.
punkmechanic
diesel tech
North East Portland Or
Three cheers for Planning, a little luck, and a dependable idi!!
punk
good job on getting home, be sure to get that headache rack (mine has saved my butt a few times)
timothyr1014
chandler. az
360k on mine....and believe me, I am not complaining...these days I typically drive about 55~60k/yr, when I used to drive professionally seeing 100k+ was the norm...as insane as it sounds there is something very satisfying about having so many problems so close together and being able to deal with them all without calling a wrecker or repair shop
Hybrid455
Sandia Park/ New Mexico
I've had runs like that where everthing seems like its takin a dump. It's just part of the cycle I guess. You'll get everything fixed and it'll be a jewel for awhile then when you least suspect it :puke: They are old trucks but they will work hard and hopefully they are paid for. Happy Thanksgiving:cheers:
GRU
fear the chicken legs
fredonia pa
guess my trip wasnt too bad at all!! its still better than a payment...
dave186
Idaho
I go crazy with the maintenance on my truck. these old trucks are so easy and cheap to maintain, i figure why not? Im fixing the leaks on my ZF tomorrow so i dont have to add fluid every 5000 miles. I also have the advantage that my truck is a service truck so if I do break down, I have everything I need to fix it with me ;)
