Muncie hydraulic pump kit 92-94 idi
cardana24
Virginia
I am selling this hydraulic pump set up It was bolted to a factory turbo engine. At a minimum the hydraulic lines would need to be replaced. This is listed as fitting a 92-94 idi. I am in central va and would prefer local pick up since some of this stuff is heavy. I’m asking $300
Here are the install instructions and parts list from Muncie.
https://www.munciepower.com/cms/fil.../Documents/Clutch_Pump/CMKF927300AAC_0194.pdf
cardana24
Virginia
cardana24
Virginia
What accessories was this pump used for?
When I bought the engine and trans I was told it was installed on a bucket truck. I assume it can be used for anything that can be operated with hydraulic pressure. Let me know if you are interested in it.
