mt 480
REBELHIGHBOY
Chester, NH
Just picked up a snap on mt480 time with everything for 70 bucks going to see if I fix this crappy fuel mileage problemm
Diesel JD
Gainesville, FL
Not too bad to use as long as the magnetic probe and luminosity probe work. There is some disagreement between people here on where luminosity timing should be set. I used to confidently state that with today's fuel, timing ought to be between 0*ATDC and 2* ATDC @1400 rpm, but a couple other members here produced charts that indicate that the timing should not be more advanced than 3.5 even with very high cetane fuel at sea level. I won't tell you what to do, but I will say make sure everything works and that if you use the recommended 20ATDC hole you need to dial in an offset of 20* and see where you are and then see what works for your fuel and your conditions. Good luck with your new purchase. Please post back with any problems, maybe we can help you.
REBELHIGHBOY
Chester, NH
Thing looked brand new no wear marks from being used or anything hope this can help my 11 MPG problem
REBELHIGHBOY
Chester, NH
Snap on Guy stopped by worked and checked it out
Said they haven't made these since 1955 but it was a good find
FORDF250HDXLT
Maine & Oklahoma
i'm in stitches!!!!
hahahaha.well i dunno about 1955 but........close enough i suppose.:D
good luck!:)
Cv axle
