Moter locked up
riphip
Memphis, TN.
As long as you don't try to crank with the starter, you can probably turn that one over. If it has not been tried before.
You won't bend a rod with trying to turn over by hand. Starter has so much torque!
frankenwrench
overkill is under rated!
Weatherford tx
Me too!-cussAnd just for the record, when I was talking about pictures above, i was talking about the Detroit supercharger. Ive seen bent rods before so I'm not overly excited about those pictures. I'm WAY more excited about the supercharger.:Thumbs Up
Me too, I need to find someone that has already done it so i can get a good idea on how. Seen a few but still would like to find a write up on it
I've seen one or two setups on here before, but it's been long enough that I can't remember much in the way of specifics. i can remember that there were problems with building boost because of the low RPMs compared to a gasser. Using a supercharger that's actually designed for a Detroit may eliminate those problems although I have no idea how much boost they will build on a Detroit.
FordGuy100
Silverton, OR
Gale Banks just did a good diesel supercharger video. Roots type blowers are...inefficient.
DrCharles
West Plains, MO
Monster truck engines tend to turn just a few more RPMs than our IDIs though ;)
The Roots blower is indeed inefficient (and the physical design makes it hard to intercool, too). Not to mention heavy and noisy. But it sure looks neat :confused: and does have a linear boost curve compared to a centrifugal blower (which boosts as the square of the rpm).
On a Detroit the blower is intended to make very little pressure - it is there to scavenge the 2-stroke cylinders, otherwise it wouldn't run. The turbo does make boost and feeds into the blower.
FordGuy100
Silverton, OR
Agreed. The blower on that duramax above was putting out 300F°+ discharge temps at 3200 crank rpm, at the ratio they were spinning it at. They tested a Whipple next, which actually was less efficient at lower rpm's but eventually crossed over and was much more efficient up top (I forget the crossover rpm, its in pt 8 of that series).
The biggest advantage of a Roots type supercharger is that there's no lag in boost. Sure they make more boost as the RPMs rise, but they don't have to have very high RPMs to start boosting.
frankenwrench
Weatherford tx
Either way, he just wants something different. He isn't going to be winning any races with this truck, doubt he's really even going to be hauling. I still think a turbo would do everything he wants to do and more, but it isn't my truck. Just a project I am going to have to do. But I'm wondering if I will have to have something machiened so that it fits on the block and whatnot. Alot to wrap my head around. Need to get the moter out and freshened up first and get it going.
In one of the threads that I saw about this, the guy fabbed a remote mount on the passenger's side of the engine. The blower sat tilted on it's side when compared to the way they normally mount. The whole set up sat off to the side of the engine.
Seven4eight
