I changed out my test gauge and hooked up a new out of the box mechanical one, and the best I can get out of it is 25 psi at 2500 rpm, 2 - 4 lbs at idle.
Ok, I took the oil filter off and I can see the regulator valve. I think it is stuck open, but not sure from this view what position it is supposed to be in. Should any of the hole in the valve be visable? I gently pried on it and I can't move it any to the left (as seen it the pic). I can move it a little to the right, but not far enough for the steel ring to touch the right side. It just seems to me that the steel ring should be against the housing on the left. Does anyone know from looking at this pic if it is stuck partially open? Anyone doing an oil change and could take a look at the position of your valve..... Sorry for the not so great cell phone pic...
Also, the filter bypass disc and spring (not shown in pic) are gone. From what I have read that shouldn't affect oil pressure, but it would allow oil to bypass the filter, correct?
Thanks alot for all the replies and help, much appreciated!!
for some reason,,that looks diff, than my bros 89 he had?? buttttttt, if the regulator is stuck open,,you will have some pressure when the oil is COLD,,but zero as it warms up.. the oil is being pushed right out the bypass.. been there. you can get the bypass out,,if its there,,you just "unstake" the stakes that hold it in there.. polish the valve,,with a piece of steel wool, to get off any burrs, then put it back together,,and restake it, in a diff spot......after i did my bros, had wayyy good pressure...i know why his stuck open,,and thats another loooong story..
