Looking 4 the FUEL CHECK VALVE LOCATION
Danny Cardarelli
Massachusetts
1994-Turbo 7.3 I.D I....im specifically looking to locate the fuel check valve
Thank you in advance
DC
If any one knows, it would be greatly appreciated
There is a check valve on the IP return line 90* fitting.
Macrobb
North Idaho
While it acts like a check valve, it's actually a pressure regulator.
It's designed to maintain a consistent backpressure(like 5 psi?) inside the housing, which is reduced to 0 when the cold advance solenoid forces it open.
Alleycat
