Light up the night with Scorpion LED Grille by aFe + New Promo
carid
Supporting Vendor
NJ, Cranbury
Do you want to give your truck a great aggressive appearance and make it visible to others? Look no further than aFe Scorpion Series LED Grille! With unmistakable designs and rugged, powder-coated steel construction, it fits the extreme off-road lifestyle in every way.
This grille directly replaces the factory part with no extra modifications. With included stainless-steel hardware and sturdy, TIG-welded mounting brackets, it doesn't only upgrade the look of your truck's front end but also protects your radiator from stones and small debris. High-intensity CREE LED lighting is included with every grille.
This fall, you have an opportunity to save 20% on aFe Scorpion Grills. The offer ends on November 30, 2020. Prices are already reduced.
aFe® - Scorpion Series Tread Design LED Grille
Features:
- One-Piece Laser-Cut Design
- Two-Stage Powder-Coated Finish
- Built-In LED Lighting
- Stainless-steel hardware is included to provide the best corrosion resistance possible for each application
Includes:
- 1-Pc main grille
- Military-grade wiring harness
- Stainless steel installation hardware
Alleycat
