onebadiditurbo
...killed truck went and ate came back outside and it wouldn't hit a lick. It turned over fine, no wet injectors caps(replaced about 8 months ago) so no obvious air leaks, have 12vdc to the FSS on the IP. Now when I pressed the Schrader valve on the filter head fuel did not come out, rather a short hiss of air, I couldn't crank and hold valve and didn't have a screwdriver to short across the starter solenoid. Tank was between 1/2&1/4. A friend of mine came and pull started it for me, started as soon as I let off the clutch, no rough idle, no smoke, but also no smoke while cranking. Any ideas.
