furfishgame
I finagled a rajay 300 onto my 7.3 idi, before i start it my question is, 1. Should i pour some oil into my turbo feed line and into the turbo it self fo i dont burn up my seals before oil makes its way there? Also, my oil return line is about level if not slighly higher going into my valve cover from where it comes out the bottom of the turbo. Is there a beter place to run it as i belive the return is gravity fed? Will it still flow where its at? Thanks!!
