jperecko
Diesel Ape
I am just about done with my transmission and the engine will be coming out in the near-ish future and I think I should start planning.
Goals-
Like everyone, I want the most power that can be had but I also want reliability, which trumps power if it comes to that. This truck is being built as an "expedition" type vehicle which means that it will be offroaded to remote locations which requires simplicity and reliability.
Limits-
Money is not too much of an issue. I can afford to spend a few grand on the engine but would like to save where I can.
I can and will fab things that need to be. Machining will require me taking things to a machine shop but when it comes to other stuff, I can fabricate a lot of specialty parts which may be needed.
Time is also not too much of an issue. This build has been drawn out so much already and if it takes a few months or more, that is not terrible.
Plans-
What I had planned on was the works, twin turbos, custom manifolds to accommodate the turbos and maybe twin water to air intercoolers as well. This would be a plumbing nightmare but would yield fast as well as big boost. I was also considering **** injection.
When it comes down to researching the specifics, I was thinking dropping the compression to maybe 18:1 to accommodate boost without hurting cold starts too much. Mahle pistons with 7.3 turbo rods and 7.3 valves and such since they are supposed to be stronger. Also porting the heads similar to what icanfixall has been doing. Oh and obviously studs
Now I am getting a little more grounded and am worrying that doing all this junk is going to be putting too much stress on the engine and jeopardizing reliability. Maybe I should just stick to a simplistic approach of a single Banks or similar turbo kit with an intercooler to "keep it simple, stupid". This setup should make good power without jeopardizing parts.
So, what do y'all think should be done? Also, what are some good sources or does anybody have any of the following parts for sale?
-Mahle pistons
-the stronger connecting rods
-the stronger valve parts
-offshore heads with more room for machining
-any other parts you think I should consider for such a build?
Thanks all and I appreciate anything on topic or not that you have to add.
Goals-
Limits-
Plans-
-Mahle pistons
