is thermostat housing bolt metric?
gem6.9
lebanon, or.
hello, i twisted the head right off the block side bolt on the thermostat housing, i thought would be a fast job to change the stat. anyways, is this bolt metric and is this a ford bolt only, thanks for any help.
typ4
Newberg,OR
No, it is standard and it is just a grade 8 regular bolt 5/16 course
gem6.9
lebanon, or.
lift pump bolts
thanks a bunch, i will be getting one after work and finish the job, the new ford stat works real good in a boiling pan of water, the old stat is real sticky, i cant wait to try it out towing, thanks agin.
RLDSL
Diesel fuel abuser
Arkansas
A lot of those fasteners make you wonder. Most of the 1/2" head ones , a 13mm socket fits better.
jorge140
