As some of you may have read, I had linkage issues with my rebuilt U-Haul.
Seems there's several versions of the throttle linkage, all important measurements are good, but between some of the cable, return spring and cold start solenoid fit's, added with there's at least one really Cheeeeeezie linkage assembly out there you may get stuck with, some of us may end up with what appears to be a slop fest.
First a few photo's 'splainin the problem visually:
Throttle cable and cold start solenoid riding all wrong on the throttle assembly
Return spring riding ******* CSS, and CSS engaging the return spring lug
Another view of CSS and return spring lug
Here's what that POS linkage slop looks like "pre-installation" and had my doubts, but did it anyway. Thought it might be an easy mod, but all the bends are wrong in this style assembly for my set up:
See the big gap here:
No big gap here, yet same part:
Ya think that could be an issue? Well, I didn't like it so went on to r/r the top end. It's not so hard to do, just be gentle with the guts and don't lose a particular "hidden" part.
First off, thanks to both gandalf and diezelcrazee for their excellent instructions. Not that there's a lot to it, but, as some of you know, I want to know everything and why the watch works when all I need is the time.... in this case.... IP's are kind of assembled like watches, plenty of fine springs in them to pay attention to. Thanks again fella's, it was very helpful.
Since I have a whole bunch of photo's, including pics of caliper differences, this might take me a day or two to complete, and will be a multiple post in this thread. There will be some steps excluded for brevity, but are done so because it really is too obvious.
