colorado_joe
I've been reading and searching all the forums, although there is WAY too much info on this site.... so I figure I'll just ask. I apologize if this is a common question I've just missed, but better to ask then make a BIG mistake on the truck.
Background:
So I just replaced the injection pump, injectors, return lines on my 1989 F250. The injectors and return line was from Type4 (thanks!) and the pump was a reman from U-haul off ebay people mentioned was a good buy. I bought all this a year ago, just never had the chance to get to replacing till now.
The truck has a C6 transmission.
Problem:
The injection pump I bought has a different set-up/bracket for connecting the throttle cable, return spring, tranny bracket, and vacuum thingy (still trying to fire that out, for now my apologies for calling it a thingy) on the drivers side.
Essentially, it's a different set-up, for maybe a different year. The difference is the internal rod that goes from the drivers side to the passenger's side, and the items attached externally on that rod, both sides.
So I don't currently have a place on the new IP to hook up the long rod with e-clip going back to the tranny. Also the vacuum thingy won't connect as it's different.
My thoughts:
I'm wondering if I should open the injection pump top cover, and remove the mechanical connections (rotating assembly including the rod) from the old IP, and put it on the new IP.
...OR...
Can I get different parts to connect to the new IP without removing the top cover. This would mean a different vacuum thingy, different return spring, and finding some way to connect the tranny rod.
Sidenote:
I am mechanically inclined (engineer) and don't mind removing the top cover. I've built cars before, body up. BUT I do want the guidance of the experts here as this is my first diesel and injection pump.
Thanks in advance. I'll see if I can get some pictures.
Background:
Problem:
My thoughts:
...OR...
Sidenote:
