alwaysdiesel
The new guy
So after replacing the IP and injectors I took the truck for a couple of spins around where I live. The truck has been sitting in my shop for a few months now. Prior to the few months its been parked It was my DD and never leaked (except some diff fluid) anyways now I have run it a bit and left it idle for 15-20 minutes to make sure I've got no fuel leaks still. I've been pretty thorough about checking return lines/inj/pump for leakage. While idling there were no leaks. Two nights ago I backed it up into the driveway (slight incline with front end facing downhill) and in the morning there was antifreeze/water all over the ground. It is dripping off of the holes in the crossmember that is next to the oil pan and right above the axle. I drove the truck to flat ground and let it idle for 10 mins then would slowly bring up the rpms. No leaking. Parked the truck on the hill again, but a different spot. I watched it and it didnt leak for a at couple of hours, not a drop. Over night it poured out and is still dripping as I type this. Looks like a good flow coming from the water pump. I'm thinking not running the truck for a couple months has dried up the seal and now its leaking. It's just bizarre that it doesnt leak out when there is pressure being put to it. I'm going to give it a treatment of bars leak and see if that fixes it. Any ideas or anyone have a similar problem?
Thanks
Thanks
