Intercooler pipe routing options (pics)
I see you don't have water/air cooler on here,
allow me to help, even if you don't care for this system.;)
jaluhn83
Upper Marlboro, MD
My setup.
03wr250f
Hamilton/Montana
I did have one water air intercooler setup. Bryan cromwells setup, But heck yeah guys add more pics. The more the merrier! Nice bullnose ic setup too! @jaluhn83
and @saburai A stock ats 093 intake hat will work with the intercooler setup. no mods needed to it besides rotation.
saburai
From the picture on the Hypermax site it looks like a different snail to me.
03wr250f
Hamilton/Montana
It does look slightly different. I will also bet that would make for a better connection, as mine seems slightly short and you have to encourage all the boots to play nice. I also dont think that the wastegate is needed, it may be needed on a factory turbo because they are pinned but otherwise I am not sure why you would need one.
jaluhn83
Upper Marlboro, MD
Thanks. Bit of cobbled together mess and apparently the pics I have on the computer suck - have to get some better ones.
I did some fab work on the intake and eliminated the snail entirely - one fewer thing to mess with and gained some turbo clearance. Don't seem to have on of the final product but these give an idea of the work - filled the gap with various aluminum plate chunks and welded the whole mess together.
jam0o0
houston, tx
looks like you missed mine
3" SS tubing, 6.0 intercooler in front of the core support. made my own hat.
jam0o0
houston, tx
No it's a factory Ford 6.0L intercooler. 3.25" inlets. Some years have plastic end tanks. Avoid those
pelky350
Springfield, OR
This seems like a place to add this also for ideas maybe??
jam0o0
houston, tx
i don't know if brick noses have enough room behind the grill. only things i had to do were cut out for tubing, cut 1" off the hood release lever, and flatten the vertical support. or maybe i took out the support. and make the mounts.
dented73
