FordGuy100
No amount of RTV will stop the leak if its coming from the high pressure side of the injectors... Try this. Remove the buggered injectors and change the bottom sections with the top body of the injectors you pulled out. I really dought the injector bodys are differant from G to any other code. Now the spring and internals are differant between injector codes. When you try to replace those lines please remove the line dampners BEFROE you try to tighten them to the injectors. They should turn by hand all the way down. Don't give up so easy. We will get you running correctly. I have cross threaded injector lines before yoo. Its no fun I know.... Funny how I can machine almost anything but try to thread something as simple as an injector line....
I dont think its from the high pressure side, that to me would mean the fuel would squirt out, the fuel is just kinds dribbling out here....but I hear you. I just dont have the time, I know I keep saying that but judging by how long it took me to pull the old ones and put in the new ones, it would take a couple hours, and I gotta leave early tommorow....I just need something that will get me from point A to B for a week or two, without having to do hardly anything (isnt that what everything boils down to in an Idealistic world ).
I dont wanna mess with pulling injectors apart, if there were diagrams maybe but that is something I dont wanna mess up.
Nope its not fun but I will look on the bright side....I'll get to do this all again in the near future hopefully this time I will take more precautions and not have this happen again.
