7.3 powerstrok
some have one some dont ,why ???? no one knows i dont know ,converter holds several quarts .changeing the trans fluid without draining the converter ,like drinking a beer with a cigrette but in it .....well get you a 1/8 pipe tap and drill bit and a brass 1/8 pipe plug ,on the converter you will see the tool lines around the surface ,look for the wider spaced ones usually at the stud but not always this is where its thicker metal ,,,on the factory ford anyways ,you need to drill 1"inch on center away from the weld around the converter this must be accurate or you can hit the clutch if to close to the edge ,i think i can post a photo of the one i installed i will post photos if any interested
