Increase the load rating of your truck with Hellwig Helper Springs + Promo
carid
Supporting Vendor
NJ, Cranbury
If you're towing a small utility trailer or hauling a heavy boat, Hellwig helper springs will help you to increase the stability and control, reduce bottoming and provide the ability to level the heaviest loads from left to right and front to rear.
Manufactured from heat-treated ASTM 5150 alloy steel, they are extremely durable and strong. They feature bolt-on design and can be easily installed with common tools and basic mechanical skills. These springs are available in the range in capacity from 550 lbs. to 3,500 lbs.
Make your towing experience more enjoyable with Hellwig Helper Springs and Get a Reward! This May, we offer up to $25 mail-in rebate on select Pro-Series, EZ-990, LP-15, LP-25, LP-35 series Helper Springs purchases. The offer is valid until June 30, 2020. Please check the following PDF form to get your rebate.
Hellwig® - Pro Series™ Helper Springs
Hellwig® - Load Pro Series™ Rear Helper Springs
Hellwig® - EZ-990 Helper Springs
JU57US
