Ignition Key powers everything but won't turn engine.
TorchMadness
Lakeland
When my key is turned over everything is powered up but the ignition will not start the truck. The starter is fine I've started the truck at the solenoid to check and run the truck after the transmission swap I just did. I also replaced the key switch just to be sure it was ok but I still have the same problem. Any suggestions on this would be helpful.
Is it tilt column?
Mine is and worn out inside....with column in straight position I press upwards on wheel forcing the actuator that much further...easy peasy..needz to be replaced....
Sounds like you didn't bypass the neutral safety switch when you installed the zf5......
Danielle
No, it's not finished
Dirty Jersey
Check for power at solenoid, starter etc. Follow that demon :(
Sent from my LG-H901 using Tapatalk
TorchMadness
Lakeland
I found it I was wonder what I needed to do with that extra piece from the C6! Any easy way to bypass it?
I think you can unplug that harness and plug in the one for the zf. That way you retain reverse lights.
Otherwise I would splice them and heat shrink.
R light requires plug that fits zf a d the wires then feed stck C6 reverse light harness...easy peasy.
N safety *** is that fer...honestly cannot recall what I did to fix that issue but Fix it I did.
olsen726
