bb's are fine an are better for your setup unless you have a 5,000 series injection pump. The 5 series is for na/turbo trucks 93/94 which send a different pulse you can run g codes with that pump they have a bigger needle an bigger bore in the body an lil bigger tip for the needle. They do give more fuel flow than the bb's with The 5,000 series pump. I have the bb's in my truck an they work well an there is dyno numbers to prove it on OB. I will be trying the g codes when I rebuild my pump in my na/93 truck an adding a turbo I will report the feed back. But the bb's are honestly good I just put bb's an a turbo cal on a 86 6.9 at my house who was struggling to see 3psi boost. now the truck is seeing 10psi an chirps the tires I cant wait to see my customers face when he punches it! It really moves along you will be happy you changed them they loose alot of performance with age an miles this truck has 110,000 miles an ran like a sick dog now its running like a rapped ape lol.
