Hypermax turbo part# ?
high psi
South Central PA
Does anyone have the part number of the turbo from a hypermax kit, or another non-wastegated kit? There should be a tag on the turbo itself. I am trying to homebuild a turbo kit using some pieces I bought from Mel. I have all the compressor maps, flow charts, equations, etc. for sizing a turbo to a gas engine, but nothing for a diesel. If I can figure out what turbo is used in the kit, I can size a turbo to my needs accordingly. BTW let me know if your kit was for 6.9 or 7.3 and auto or manual. Thanks!:thumbsup:
Just so everybody knows, he has the exhaust housing but that's it. He's looking for a center cartridge, wheels, and intake housing, for what would have been a non-pulse or van only turbo kit.
high psi
South Central PA
Thanks for the clarification Mel. I'll take the numbers off of any style kit though, I plan on building a turbo to my own specs once I get some kind of a baseline to start from.
Michael Fowler
Bel Air, MD
I think the equations are the same, gas ot diesel. Diesels do not rev as high, but thats part of the equation.
Here is what I have computed:
TURBO CHARGER CALCS
1) Volume of AIR in CFM
displacement: 420 cid
engine speed (rpm) 3200
Volume = 388.8888889 CFM
2) Air Flow in POUNDS per Minute
BOOST 6 PSI
est. air Temp 200 no intercooler
32.96478296 lbs/min
Corrected for efficiency of 60 percent
Corrected AirFlow = 19.77886978
3) EST HP = 198
4) Pressure Ratio 1.408163265
The ats and ford oem are garrett TO4H. The compressor is a .70 ar, I am rebuilding a banks non wastegated for a member and it has a super 60-1 compressor, it looks like the one I put on my ATS. The turbine is quite a bit bigger on the banks than the ats I am guessing that is why they spool slower, the exh housing is 1.00 on the banks.
ntjapkes
