Hydroboost output shaft
Philip1
Northeastern Nevada
Those of you who are wanting to switch to hydroboost brakes but are struggling to find boosters with the output shaft included. There is a replacement shaft available for them. There is a big bored version and a small bored version. When I was working on installing my system I used the small bore version.
Small bore:
https://www.ebay.com/itm/hydroboost...803109?hash=item341c856325:g:lcAAAOSwHuxdlP5~
Big bore:
https://www.ebay.com/itm/Hydroboost...a=1&pg=2332490&_trksid=p2332490.c100930.m5375
Sent from my SM-G975U using Tapatalk
Philip1
Northeastern Nevada
They do require some modification however the directions are included
u2slow
bilge rat
Coastal BC
I bought Motorcraft hydroboost for my 95 F350. (F450 application) It came with the pushrod.
nj_m715
government's finest
NE of Atlanta
I rounded over a hardened bolt. I think it was 3.25 in of 3/8 bolt but it's been a long time.
Clb
Another old truck
nannyfornia
The ford unit comes with the push rod along with the little return\holder gizmo.... nearly none of the aftermarket ones do.
so this could be a godsend as ford units are at 2x aftermarket units...
jrollf
Houston, TX
I can't find a Ford unit, every source I look up says "discontinued"... any idea where to find it? Looking for part number E8TZ-2005-B correct?
Clb
Another old truck
nannyfornia
I bought one on epay a couple yrs back...
try the stealership?!
Hagan
Oregon
They are discontinued. I bought a new one a couple years ago for my Bronco. I'm planning on going with a Superduty hydroboost when the time comes. It will take some work on the mounting plate to get it to fit.
chillman88
Central NY
I had purchased mine through RockAuto. I looked and sure enough not listed anymore. That's a shame.
Thewespaul
Bulverde, Texas
I’ve got a couple, I’ve been working on putting together a hydro boost conversion kit to offer but the availability dropped out almost overnight. I’m going to use the super duty boosters instead, just going to require more work.
