will that unit work in a 1985 truck or should I find one closer to the correct year?
YES
BUT...BUT...you'll be fabbing/modding the mount plate with the 4 studs to relocate to the same pattern as your truck. You will also need to custom create some HI pressure lines!
I recall there being a difference between '99+ and '97 down hydroboost units, but I'm not sure what the difference is, nor how easy it is to retrofit one for a later truck onto an earlier truck. I would suggest anyone who's considering this get that question answered before pulling the trigger...
Bolt pattern as mentioned above, and the HI pressure lines are metric threaded instead of SAE
I'd guess the later ones wouldn't bolt up to the same 4 square pattern. Everything else on them is metric so I'm better they changed those measurements too.....
Now how much of a pain it would be is another question..... try it and find out.
You are correct on both parts....
I had to weld up the holes for the studs..AFTER pounding out the studs, then grind flush, then redrill the holes to the correct pattern.
Hope this helps out enough...
JM2CW
Al
