Cruiseomatic
Defining Insanity
Looking to put hydroboost on my '87. What years will be bolt on setups? I've read 87-97 will be. Also read alot of contradicting information and most was from 09-11. Not much that was recent.
What all would I need to complete the conversion? I know the unit, PS pump reservoir, and lines. Also heard I would need to get a cooler with this setup. Tried reading as much as I could but just got lost in all of it.
Is there a list I could reliably go off to use for a parts list? Install looks fairly straight forward unless there are torque values I haven't come across.
As for the PS Pump, I'll most likely just replace mine totally as its oem and the shaft is bent.
I did find a new motorcraft hydro unit but wondering if its like the rest and doesn't come with the rod, Or does it?
Thanks
Thanks
