Hydro-stop kit #3 1996 F-Super Duty
lindstromjd
Black Sheep
West Des Moines, IA
I have a hydro-boost kit from a 1996 F-Super Duty truck for sale.
Includes: hydro booster, both pressure lines, PS reservoir (no pump) with 3 ports, and brake pedal assembly for an automatic
Should be everything you need to swap out your old vacuum booster that doesn't work anyway and get some real stopping power. You can keep your old master cylinder and not have to bleed out your brakes this way.
$200 firm + shipping
This is the last kit I have. Since IDIoit called first in line on the other thread, he can have until midnight to claim this one. Then, M2bdriver has a chance. Otherwise, it's up for grabs from the general population.
cpdenton
Truck needs paint.
Conway AR
You must have ran across a pretty sweet yard somewhere lindstromjd. All 460/auto trucks? Been trying to find a power stroke passenger battery tray/radiator overflow/windshield reservoir.
lindstromjd
Black Sheep
West Des Moines, IA
Yes, those F-Super Duty trucks were all 460/auto. But there is one OBS PSD in that yard. Relatively untouched. Send me a text and I'll try to remember to grab those for you.
cpdenton
Truck needs paint.
Conway AR
Fun money is a little low right now, but I will get in touch in a few days.
FYI, i will have an extra battery tray in a couple months. i need to install the ones in my 94,
i also have a set of brick nose ones i wont be using.
mu2bdriver
CT
If you come across another one in your travels, please keep me in mind.
Thanks again!
Brick nose battery trays you say..... I think I have 2 good ones but they are both for the same side....
cpdenton is looking for some...
not I!
I have a few spares. let me piece the OBS ones together and see what I got. maybe I have the other sides lol
cpdenton
Truck needs paint.
Conway AR
I am specifically looking for one from a power stroke. The stroke overflow bottle and windshield washer bottle bolt to the passenger battery tray, only reason I need the tray. I am trying to get rid of the banks sidewinder filter, it is junk. I want to try and adapt a power stroke intake to it.
Another option may be a stock 6.0 Air Filter System. It mounts toward the drivers side but stands up between the drivers side battery tray and the radiator. However, the washer tank on a 6.0 is buried on the passenger side under the battery area somewhere (all you can see is the fill tube) and the overflow bottle is a degas bottle and is mounted to the cowl above and to the left of the brake master/booster.
It is right beside the battery with the clips on it. If you want better pics, let me know I can take some of mine over the weekend, this is one I borrowed from google.......
They are good up to about 500hp (Plenty for an IDI) but the filters are expensive. They are a Donaldson Powercore Filter:
https://www.donaldson.com/en/engine/support/datalibrary/059806.pdf
The 6.0 Filter is rated at over 3 POUNDS of contaminates before it is considered dirty enough to replace. I have not replaced mine, so I know there is at least 70,000 miles on my filter...... could be the factory one at 150,000 miles. Still working fine.
Just another option, everything under the hood of a 6.0 "has a place" since it is quite busy under there......
Sorry about the hijack.....
not I!
What I meant was I think I need a good brick nose battery tray but I'm not sure which one.
Sorry for the hijack too.
Alleycat
