HP/Torque numbers guess
gumper
I rack my brains every other day calculating and pondering this question. How much power and torque does my truck make? A dyno is getting put in 120 miles from me, but won't be there for a few more months. What do you guys think? You can see all my mods in my signiture. I guessed from 430-450, but I'm sure I'm wrong. No idea where the torque is.
holtzer1
missouri
what are your performance mods...written out?
i'm not into deciphering all the mods
Mike
Stroker
Cora
Looks like an air filter, bigger fuel plate and delivery valves and an exhaust?
gumper
Cold air intake, ATS Arc-Flow, 15* timing, #100 fuel plate, 3000 GSK, 191 DVs, Dynomite Diesel DDP3 90 hp injectors, 4" exhaust.
Mighty Dodge
MD
430-450 sounds about right. But there's only one way to find out for sure.
rubberfish
Langley B.C.
I get those numbers with my setup.
So,,, go from there I guess.
Personaly, I think you've got a bit more
spending to do to get to the 450 rwhp mark.
A lot of this dependes on your pump, turbo
and on and on. It's hard to guess these things.
However, if you do hit 400 rwhp, with the model of
Cummins we're running, that would be 1000 lbs to the
ground. With a 24V, you'd need to do 500 rwhp to hit 1000.
MadScientist
