If your willing to do that kind of swap again and throw that kinda money around I'd say screw changing out that ATS turbo system for a Banks or Hypermax. All 3 are going to be similar in performance. If you want better performance than one of the "big 3" build a setup of your own. THere are much better turbo options out there than the Big 3.
Just my .02
yeah, it wasnt my intention to put out that kind of money ... just added up a few hundred at a time ...
I am attempting to not add additional expense ... I have the 93 idit in the "driveway" right next to my 92 ... the only "expence" that I will have is the time/effort/labor of removing 2 engines, swapping parts and re-installing them ... plus fluids/filters/gaskets etc (minimal expense in the grand scheme of things)
I did not know if garrett was the same as ats or differemt ...
I was wondering if the garrett turbo was better/same as the new banks one I have already on the crew cab ...
My thought was to take the block/heads from my 93 idit and all the new bolt on components that have been installed on the 92 idi and marry them together for a still mostly stock, relativley no more expense reliable driver/tow rig.
I have always liked the crew cabs and have had a few ... usually with the 460. I found a crew cab diesel 4x4, swapped my rear dually axle and fender flares from an older gas dually ... bought the spacers to run dually wheel in the front ... and thus I have my 92. I dont plan on replacing this truck any time soon ... so last summer when the shop did all new suspension/steering/clutch/turbo etc, I was just thinking it makes it more reliable and dependable ...
Following that train of thought, I figured having the bigger writ pins etc would make for a more reliable powerplant ... I have every intention of selling or scrapping the ext cab anyways, so why not use what I can first? my block is still good and is a runner ... I plan to turn up my boost, and want to make sure I wont blow it apart ...
before I scrap/sell the other truck, I will first put it back together and try to sell it whole ... but Im not against parting it either ... I could put the 7.3 into the 4x4 van ...
