How do I stop the crank from spinning?
masonfamilyo4
Brooksville FL
:dunno How do I stop the crank from spinning? I need to remove the harmonic balancer and cant get the bolt loose. Is it righty tighty lefty loosey? Thanks again.;Sweet
sle2115
NRA LIFE MEMBER
Southeast Ohio
An impact is your friend! They will bring them right loose. And yes, all the ones I've been into were right hand thread...or lefty loosey as you put it! ;Sweet
There is thread locker on the bolt, yes lefty loose. Impact is the only way, other than a chain vice grips on the damper.
RangerDanger
