65sixbanger
Sounds like some thing is too tight. Did you put new main bearings in? If so, and you didnt set the thrust bearing to the right clearance it couldve got hung up...
There should be eight pieces of flat stock that are slotted. Each piece holds two LIFTERS at a time so they cannot twist and turn. Once you start putting it together you will figure it out. I will try to post some pics. And I wouldnt worry about the hole, since these are hydraulic lifters its probably some sort of drain, or beather to help lube it up.
What caused all this build up on those two cylinder heads?
