Whit
I have been having trouble keeping my intermediate boot in place above 25psi, this boot is the first one from the discharge of the compressor, I blew it a year ago and simply had to remove clamp and reseat the boot and then retighten the clamp, well it happened again while towing my 5er up a 7% grade, when the boost maintained 25psi or above it just couldnt hold any longer, had to do the whole trick on the side of the road, got up to our camping spot on a friday and called Piers at PDR and said send me the high pressure units I cant take this crap anymore. They arrived today and I went out and did the trick, these new units are 2x as thick of rubber compared to the oem units, and they are tough to put on, tight fit big time, I am happy to report that a test spin let me know that 38psi is fine and I am sure these boots could take alot more from the high powered units.My recommendation for these boots is strong and I cant see where you can go wrong with them.
2 thumbs up for Piers and his high pressure intercooler boots
Cheers, Kevin
Cheers, Kevin
