Hybrid455
A few wks ago I posted concerning a major swap project I am doing with two trucks. One is a 7.3 DMF ZF and the other is a 6.9 auto.
I have both trucks spread all over my garage and ran into a hitch. Keep in mind this is a budget job. The dual mass flywheel I was going to reuse with the ZF is wasted. I have access to a 6.9 flywheel and thought about using it with Cheaper Jeepers genius but I am concerned about balance problems. See these 2 threads.
http://www.oilburners.net/forums/showthread.php?t=7639
http://www.oilburners.net/forums/sho...t=16973&page=2
If the 87 6.9 and 7.3 flywheels were the same per agnem article was Ford just being overly conservative? Has anyone used the 6.9 SMF on a 7.3 with Cheaper Jeepers pressure plate and disc and zf with any success? I don't have $600.00 right now for a conversion kit and I have to wonder how much difference there would be between the OEM 6.9 flywheel and Jeepers part numbers and the aftermarket conversion kit.
Suggestions??
Suggestions??
