94_dieselpower
Well hello Oilburner Community!
I have been on this forum for a little while, I just haven't posted much. I have to say, of all the forums I have been a part of, this one is hands-down the best one!
Okay, down to business. The vehicle in question is a 1994 F-250 turbo diesel, 5-speed. My wife was driving it the other day, and called me to inform me that the headlights had just "magically" stopped working. She was able to get home safely, and we parked it. So, I hopped on Oilburners and discovered this is an all to often occurring issue. I did some reading about the headlight relay mod, of which I plan to do. I have not been able to look at the headlight switch at this time, but I am expecting that it will show signs of electrical overloading. Since I haven't looked at the headlight switch, I do not 100% know what it looks like. The following link is what I was looking at to replace the headlight switch:
https://www.rockauto.com/catalog/moreinfo.php?pk=1004233&cc=1124783
Is that the correct headlight switch? I also plan on replacing the connector going into the switch. Also, does anyone know of a good source for this part?
In my reading, I saw multiple post saying if a person is going to replace the headlight switch, they should figure on replacing the dimmer switch as well. Just to make sure, is the dimmer switch the "stalk" on left side of the steering column, which also operates the windshield wipers? Would it be good insurance to replace the dimmer switch, even if it has been working? If so, is there a particular brand of dimmer switch that I should look at purchasing?
As I mentioned earlier, I fully intend on doing the headlight relay mod. I looked at the write-up that many people have listed, and it seems pretty straight-forward. The only thing I have a question about is regarding the in-line fuse portion of the wiring. I saw somewhere (can't remember what post) that someone cautioned using in-line fuses, but rather a person should use in-line circuit breakers. From an automotive standpoint, I am not familiar about a circuit break. Do they look similar to a fuse? Does anyone have any recommendations for a source for an in-line circuit breaker?
Finally (I apologize for the long-winded post) I have seen people mention other relay modifications. I believe (please correct me if I am wrong) another main mod is a running light relay, which I understand to be the cab lights. I do plan on putting in a relay for the running/cab lights, but I was curious if there are other lights that would be recommended to be put on a relay?
Again, sorry for the long post, I just want to cover my basis here. Thanks in advanced for your help!!
