longhorn795
okay so my headlight switch has been acting up on my 89 ford for a while now and just when im driving down the road the park light's and headlight's start blinking off and on, so on my old switch i would have to find a sweet spot as i called it when both the park light's and headlight's work, so i baught me a new switch today and stil doing the same thing, when you pull the switch all the way out only the headlight's will work then if you push in jus a lil bit both park lights and headlight's will work, then if you wiggle the switch a lil they will start flashing on and off. I dont know what's causing this id figured it was the switch but it's not, could it be the rod that you use to pull in and out of the switch?, because when i baught the new one it didnt come with one and i had to use my old one. thanks
