head gasket and bolt recomendations?
Black dawg
sw mt
tore into the burb for another leaking head gasket, found failed gasket and bad bolts. When I torque 6.5 bolts, I follow the 50 pounds then ninety degrees, but I also set the wrench to 100 pounds on the final ninety degrees. The wrench always clicks just before the 90 degrees, so that I know the bolt is good. I checked these bolts before I removed them and they wouldnt get any tighter than 80 pounds, and felt like they were going to break.***?
