fsSnowboard
This is frustrating. Every time I post a question it’s because I'm having trouble starting my truck. Anyways, I thought some of my glow plugs were dead, but I did the test light test on them and all of them lit up. So, I continued with the tests found in my Haynes Diesel Engine Repair Manual on page 3-42 and 3-43.
For people who don't have the book I will write the steps so that everyone knows what’s going on.
Wiring Harness Check
1. With the engine and ignition off, disconnect the wire from GPs.
2. Remove cover.
3. Using an ohmmeter or continuity tester, check for continuity between each glow plug lead and the test terminal.
4. Reconnect GP wires.
Results
0 ohms in each lead. (A photo of the setting I had for the ohm meter http://flickr.com/photos/fssnowboard/194838670/ the switch is pointed to 20k)
Control Unit Ground Test
1. With the engine and ignition off, connect an ohmmeter to the ground wire terminal eyelet and to the ground terminal on a battery.
2. if the resistance is more than one ohm, clean or repair the ground connection.
3. If the resistance is more than one ohm, perform the supply voltage test.
Results: I got 0 ohms with same dial position as test above.
Supply Voltage test
1. With engine and ignition off, connect voltmeter to the control unit power terminal.
2. If there is less than ten volts, repair the wiring or recharge batteries.
3. If there is more than 10 volts, go to ignition switch test.
Results: about 12.3 v
Ignition Switch Voltage Test
1. Connect the voltmeter to the ignition terminal on the control unit and to ground.
2. turn the ignition switch to on, all accessories off.
3. If there is less than eight volts, check the fusible link, recharge the battery or repair wiring.
4. if there is more than eight volts, go to control unit function test.
Control Unit Function Test.
1. with engine and ignition off, connect a test light to the test terminal on the control unit.
2. have an assistant turn on the ignition switch. compare the amount of time the test light stays on to the test light chart. Note: WTS light may not come on if the engine temp is at or near normal Operating temp. Total test light on time is measured from the beginning of the on cycle to the end of the last on-off cycle.
3. if the test light is incorrect, disconnect the ground from batteries and replace the control unit.
4. if test light time is correct, control unit is OK.
Results: first test, 21 sec, counting in my head. second test was 17 using stop watch. 3rd test was also 17. Now, it is 85 outside, so the unit has to be at leas 70 degrees.
Control Unit Temp WTS lamp on time Test light total time
35 F 5-12 15-35
70 F 3-5 7-15
105 F 1-3 3-5
There is a note saying control unit temp is no ambient temp but temp of the control unit.
So, i think i have a bad controller? The WTS light stays on about 10-12 seconds.
Another note, earlier with everything hooked up, i only heard the clicking of the GP controller only once, and kinda heard a whining/wheesing sound at the same time.
So, would my broke GP controler make my rig hard to start?
One thought i had was, could my fuel filter be letting air in. I changed it last summer, but since then its been a little harder to start. should i just tighten the heck out of the filter?
Thanks for the help guys.
2. Remove cover.
Results
Supply Voltage test
35 F 5-12 15-35
70 F 3-5 7-15
105 F 1-3 3-5
