Got her Running again!!!!
Pull-n-TugTx
Weatherford Texas
So last weekend I switched tanks. Pump kept pulling from the Rear tank ( I was "running" on the front). Tank ran dry. Trucked died. Went through the usual and still couldnt get any fuel at the filter. Replaced the Fuel Switch Valve, $380:puke: from dealer. Still no fuel. Replaced the slightly used pump with a new Manual LP. Still no fuel. Installed a temp Electric pump, Mr Gasket # 12, to trouble shoot with. Cracked a couple of injectors and SHE ALIVE!!!! Now Im awating the Carrier LP from GennLighting. Then I will be permeant, hope to have this all done right next wknd.
Took it for a run this evening to clear it out a bit. Im noticing that it still dosent seem to pull from Front tank when selected. I do notice the Rear tank getting lower.
DO you think the Front tank Sending Unit has gone out?
To icanfixall and DesertBen44 :hail;Sweet; Ya'lls right ups and pics got me through the pump install!
How much fuel is indicated in the front tank?
Could you be suffering from the dreaded SHOWER HEAD issue?
Sounds like that's what's going on to me ....Is that FSV you installed a FORD one or aftermarket?
I used that same MR Gasket pump for my install too, seems to work ok for me for now, and yes Carrier pump is next!
Glad you could use the info onsite for your benefit.
Pull-n-TugTx
Weatherford Texas
Front tank reads FULL past the F!!:dunno
The FSV was from Ford dealer. Parts stores offered a Universal one for a lot less. The Return lines where in the wrong spot and the Plug for the wiring was WAY OFF!!
jim_22
Cape Cod, MA
I had the same problem. You can find the wiring diagram online. Let me know if you want me to send it to you. You can test your switch by seeing that the voltage changes on the proper pins. Then you can unplug the harness at the fuel valve under the truck and see if the voltage is present there on the proper pins. For me everything checked out there pointing to the 6-way pollack valve as faulty. With the harness plugged in I tend to blow fuses so I think there is a short i inside the valve. I did not get around to changing the valve yet so am always running on the rear tank, which at great expense at least is brand new. Always something, but got to love the IDI.
I'm happy to have been of some help to you... Thats what this forum is famous for... Helpig those that need the help. We offer free help... Now go to any dealer and ask for free help:rotflmao.. Those guys could use a good laugh now and then..:angel:
Pull-n-TugTx
Weatherford Texas
I had the same problem. You can find the wiring diagram online. Let me know if you want me to send it to you. You can test your switch by seeing that the voltage changes on the proper pins. .
IF you would please send me that diagram. Im looking at either the switch, or a bad return line, or seal at Rear tank sending unit. Causing a vacuum loss.
Thanks
Nanohawk
