Hey guys I just got my engine running finally and I have been sitting around thinking about what I dont like about the ATS turbo kit and what I do like about it. In the end I may not change anything but I think I can do better with 2 smaller turbos. I dont need to make anymore power than I planned but I am really hoping to cut down on my egt's. I personally feel like the single turbo and especially the ATS exhaust feed pipe cuts down on the potential of the engine and causes a big heat build up. Im hoping the 2 smaller turbos will work about the same but hold off egt's with a bit more flow but yet the same if not more agressive boost curve. If I dont see results I will put back on the ats kit and see what I can do with it. Either way watch for picks in the next month or so. I will be working on the twin kit and I will try and post pictures as I go. Im thinking of some gt25 turbos with .40 something A/R ratios. Each will have a 2.5" down pipe merging into a 4" pipe. I hope it works, I will just have to wait and see.
Lastly my reason for trying this-never seen it done and I still want to try something with these old IDI's. I have a 2" body lift so there is plenty of room. If all else fails I will still be able to say I atleast tride it.
