JSVD
My glow plugs arent working. So i went out and tested the grounds - theyre all good. Then the relay - it was getting 12v from the ignition, but not clicking over. So i figure simple fix,its the relay. Swapped that out and i get the same symptoms.
So i read a bit and find something that says if i ground the small post opposite from the post with the ignition wire, turn the ignition on, and it clicks over then i have a glow plug/harness issue. It clicks over when i do that test so i went through all the plugs (which are brand new motorcraft) and the harness and everything checks out fine.
So thats where im at. Could the controller be shorted out internally? What should i check next?
Thanks
Thanks
