yARIC008
Drives really slow
Okay, so I have this IDI, it's not a ford but a mercedes. It's my friends that I'm trying to get running for him. He got it for cheap from on of my dad's friends. Anyways, when we got it all we were told was that the IP went bad. The guy that owned it before got ahold of a new/used working IP but then someone gave him a new card, so he ditched this one. So anyways, trying to make a long story short, we get the car home. Starter doesn't work. We replace it still doesn't work, turned out to be a lose ground strap to the engine. We get the starter working finally...
Before we try to start the engine I changed both fuel filters and filled the new ones with fuel cleaner and fuel and put them back on. So we try to start the car... one of the fuel filters is clear so I can see fuel going into the filter from the lift pump or fuel pump, so that's working. We try to start for a few mins while letting the starter cool in between trys. It tries to start but not quite. There is only a faint white smoke coming out the tail pipe that smells like burned oil...
So next i cracked open an injector line and there indeed fuel going to the injectors as fuel was coming out the line when trying to turn it over.
So I guess my question is.. in what manner can injection pumps fail? Can the pump be getting fuel to the injectors but not getting the pressure high enough for the injectors to pop open? Maybe Mel would have the answer to this...?
Anyone have any idears? My next thing to try is WD-40 in the intake to see if it'll fire off a little from that to see if the engine can run.. if that doesn't work next step is to check compression...
