GearVendors behind ZF5 4x4 - Anyone done it and care to share their setup?
Black dawg
sw mt
I think the double over is fine. My thought is why would you need double over while in 4wd? What's the minimum speed for a gearvendors anyways, 50mph? If you're in a low traction scenario that requires 4wd should you really be driving highway speeds? I'd have the gearvendors after the transfer case, that way you're only buying one shaft.
Gv functional working speed is somewhere between 15-20 mph depending on rear end gear ratio. It has to have a certain amount of driveshaft speed to engage......even without the GV supplied electronics. You can turn it on moving slower, and it does nothing until you reach that speed.
BlindAmbition
SoCal
I spoke to someone at Gearvendors who returned my call. They said 4x4 could be used if it was before the transfer case. It still requires a minimum speed, so I'm not sure how useful that will ever be, but good to know.
BlindAmbition
SoCal
I have two GV units. Maybe I could double them like the rock crawler guys double up transfer cases
I'd be driving down the freeway at idle speeds
If I get enough of them maybe I wouldn't even need a driveshaft at all, just straight from transmission through a series of GV units to the rear axle.
BlindAmbition
SoCal
Update on this, I got the setup on the bench and bolted together. Bolted to a wide ratio 460 ZF5 that I'll be either swapping cases on or drilling to fit. Will need to create a brace to handle the weight as well.
The_Josh_Bear
Western WA
Shoot, I do this on purpose just to go for a fun drive in the snow! The people out here are scared of the snow...I love it. So a few times a year I get to run around at 50-60mph on the un-plowed freeways while everyone stays home cause driving is scary! LOL
Good to know, it seemed to me that 4x4 wouldn't matter if it was before the T-case since all the power goes where it should.
That's pretty cool! I hope the t-case linkage isn't too much of an issue.
hesutton
The Anti-Anderson
Bowling Green, KY
Have a US Gear UNDERDRIVE on my '86 crew cab that i put a 460 ZF5 in. Love the underdrive. The F350 SRW has 3.55 gearing in the axles and it cruises well on the highway. However, when hauling, the underdrive splitter is king! Makes moving weight much easier. It turns my ZF5 into a 10 speed.
Love that the US gear as it allows me to underdrive 4-low when reversing a trailer/camper. This is especially helpful when backing up a slope.
Heath
BlindAmbition
SoCal
@hesutton I have a US gear underdrive as well, not setup for ZF5 though. Would you still recommend it with 3.73 or 4.10 gears or would you rather have an overdrive then?
No they don't work that way. They bolt onto the back of a transmission and only shift to a higher gear or a lower gear.
REM70
Staff online
