burt
Hey guys, just got a p type gear vendors off of ebay. Its one for a 4x4 with a bw 1356 adapter so it should be about perfect since both my trucks fit those parameters. The seller gave a 14 day return policy so i want to test it asap. I won't be able to get a permenent install done in the alloted amount of time due to minor parts gathering i need to do to get it just right but want to confirm it works before time is up. I can't really get the electronics set up right with the parts I have so my question is can I run a 12v hot from a toggle switch in the cab to one blade on the solenoid and a ground to the other blade on the solenoid and switch the toggle switch when im going 30+ mph to see if it works right? I know I need to be going fast enough and not in reverse or 4x4 ect but is this all that needs to be done to check its function. I belive I can get it installed well enough to use with parts I have tomorrow but doing it right is going to take a little longer than I have. Two trucks are 1) 1990 f350 4x4 zf5 reg cab long bed 2) 1993 f350 4x4 zf5 cclb, man I need to create a sig so I dont have to say that every time
