ghunt
In light of my recent posts about diesel prices jumping, I went ahead and filled both tanks last night. Now, this is the first time I've used the rear tank since I put it back into the truck.
After filling up I went down the road, and I was afraid it would probably stall when I switched to the rear tank so I tried to do it while I had some momentum. However, the actual changeover took longer than I expected and the truck stalled out once it finally did because I was coming up to a light. Also the fuel filter light came on as soon as I switched to the rear tank.
Anyway, I had to pull it off the side of the road and bleed the air out of the system. I got it started again, still on the rear tank, and it ran for a minute or two and died again. I switched it back to the front tank, again bled the air out, and finally got it restarted again, and also noticed the fuel filter light was now off.
So what's that all about...I recently replaced all the hardlines to the rear tank with rubber hose because the hardlines were rusted through. Could it be sucking those lines shut?
