fuel return priming system...
DaveBen
Ukiah, Ca
It is pretty amazing when it finally starts! Good feeling, congratulation!
Selahdoor
Index Wa
And dude! All that other work was not a waste.
You learned a lot more than you would have, had it just started right up with little effort.
Vern
Albert NB
it lives!! haha swapped the batteries out cranked for about 5 seconds and dialed too life.. I didnt see it leaking around the caps either so i think shes fixed haha i let it run for a bit.
Great! If you can watch those videos above, tell me how fast it was cranking in comparison.
Nick_Rego
California
definitely the first video. i never really paid much attentiok to how fast it was turning over but seeing it with a new starter and fresh batteries was night and day. im just glad to move on to the next challenge a leveling kit i bought for it awhile back. Thanks guys for all your help.
Plus you should always replace the batteries as a pair. The weaker battery will put a drain on the stronger battery. This is why I would never own a battery powered golf cart. Those are expensive batteries.
chillman88
Central NY
I learned that one cannot get ingnition with spraying ether in the absence of fuel.
That's not exactly true.... If you use too much it will ignite, just not when it's supposed to, and you instantly feel bad for that poor engine because of the sounds it makes. I thought for sure I'd busted something but I guess I got lucky.
Nick_Rego
California
just as an update it runs and dosent leak and it starts right up now even in 30* wearher which is cold for California... anyway that check valve and return line delete were definitely worthwhile even after all the extra bs... but im not out of the woods yet haha but thats a story for another thread...
A HUGE step has been accomplished. There may be several more steps, but that's the way it goes with old trucks like ours.
nelstomlinson
Delta Junction AK
I did some calculating the other day. I figure that the passenger side battery does about 2/3 of the work in turning the starter. That one gets the heaviest load, and if it's a little weak, you have a big problem.
Vern
Albert NB
The best resistor I ever saw was the PO's aftermarket battery terminals on my '91. He had used the cable clamp type and on each bolt, connected the driverside battery and starter line. Bad bad bad line loss.
Vern
Albert NB
night and day.
Sometimes it's hard to determine exactly what the situation is. It could be one thing. It could be another. When we volunteer our advice, we aren't look ing at anything. There's so many things it can be. Bad connection. Bad solenoid. Bad battery. Bad something.
I guess I got lucky
Those are nothing compared to the sounds that came out of mine after replacing injectors. Teeth grinding, hair pulling, stress out noises of interference and or ...
I understand you're point. As it was, if injectors aren't popping, ether isn't making any "vroom" in these engines.
tinrat
Central Illinois
You are way over complicating things.
1. Changing the oil filter will in no way affect how your truck runs.
2. Maybe something has changed, but some members that tried the early rails had trouble getting them to seal. There's a lot of tolerance in the injector height and spacing. Basically what I'm saying is the injectors may not be centered in the rail. IE: causing drain back.
There's a duck bill in the tank on the return line that is supposed to help keep it from draining, when not under pressure. Maybe yours is gone. You don't want to add anything else to the return system, as that will affect ip housing pressure.
Long as the check valve is diesel rated, it will work.
You could also just swap to a electric pump. I don't think I've seen anyone do it, but you could put a electric pump between the mechanical lift pump and the filter.
I have a $12 electric pump between mechanical pump and filter I turn it on for a couple minutes before I start truck. Don’t seem to matter if its on or off after truck starts.
Electric Fuel Pump 12v Universal Transfer Inline Low Pressure Gas Diesel Gasoline Fuel Pump for Carburetor Lawnmower 2.5-4psi $12.98.
And as for check valves:
4 Packs 3/8 Inch 10 mm Non Return One Way Check Valve Aluminum Alloy Fuel Check Valve for Petrol Diesel Oil Fuel $13.99 w/free shipping!
tinrat
Central Illinois
No, steve, I'm not sure. Temperatures have been low enough that I'm not trying to work on anything I can't start and drive into the shop.
Next time I get my problem child into the shop, I'll put in a new e-pump, change out that Schrader valve and the fuel filter, and remove the return line from the fuel filter housing. I also have new seals for the supply hard lines between mechanical pump and filter, and between filter and injection pump, and some low-durometer orings to try to seal the stupid return caps that won't stop leaking now that I put on new caps and new orings.
Yes, I did carefully check the inside of the new caps and they were smooth. I did lube the orings, and I did feel the return caps snap down into place.
Question? Why couldn’t one put a check valve into the line returning fuel to filter? It would benefit by not allowing fuel to be “sucked” from filter while sitting yet still allow excess fuel to be returned to filter posing less “push” on return to tank lines while running?
tinrat
Central Illinois
fuel heater o rings leaks are a common source of air leaks. I hope some of this helps get your truck started.
I hope I ain’t ******* anybody off. I am not a mechanic. I work on my own old stuff because I was brought up poor. I can usually get by on older. Diesels because they don’t require sophisticated electronic knowledge. I hate making people rich that don’t deserve it. Just call me cheap! I think these work fine as I use them anytime I have to remove the returns. Instead of paying $14 for 16 orings to fit an idi, I use these:
111 Viton O-Ring, 75A Durometer, Round, Black, 7/16" ID, 5/8" OD, 3/32" Width (Pack of 50) $3.30.
111 , 0.424 Inches , 0.103 Inches , 50 , 0.103 Inches , 5/8 Inches , 5/8 Inches , 0.424 Inches
