Fuel pump not running after running out of fuel
You do not have an in tank fuel pump in these IDi`s.
The only fuel pump is on the lower driver side of the engine. It is an engine driven pump.
Is this truck a factory installed IDI? or did you swap an IDI into a gasser truck?
Did you add fuel after running out of fuel?
Wondering if you ran out of fuel at 1/4 tank, if so then the shower head is probably broken off and the pick up tube is above the fuel level.
natesewell901
Millington Tennessee
It’s a factory idi qnd I had no clue i by passed that pump and installed a inline electric pump. I filled the truck up after I ran it out and I can get the truck running off a can of diesel but when I put the pump on the fuel line it won’t pull fuel
Selahdoor
Index Wa
Yep. No in tank fuel pump with a diesel.
If your tank is full, but your electric inline fuel pump is drawing no fuel then you have a blockage issue. The pickup in the tank is blocked. Or the lines are blocked somewhere. Or the fuel selector valve is not working.
quickster
S Carolina
Did you remove the factory lift pump? You can diconnect the fuel line before the filter and pull a vacuum to see if you get fuel. if you don' t get any chech the fuel selector valve. You can put your fingers on it as you toggle between front and back tanks. If you don't feel a big click, there's your problem.
jorge140
